Acura Integra - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2004, 11:16 AM
APACHEMAN's Avatar
Acura Integra
My friend has an Acura Integra that is overheating. We think it is the Thermostat. Is the Thermostat located on the side of the engine between the block and a cast part that the hose attaches too. I only looked at the engine so I didn't look in the hose. We're at work so we can't mess with it right now. Thanks for anyones help. The cast part the hose hooks too has some sort of bleeder nut on it? Thanks again.
Old 05-11-2004, 11:32 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
It's in the same spot as most t-stats. I don't really know what you are talking about, but it sounds about right. Just follow the top hose from the rad to the top of the block, and the housing that it's connected to holds the t-stat. You should have no problem!
Old 05-11-2004, 11:33 AM
APACHEMAN's Avatar
Thanks. Thats what I thought, but I know nothing about these rice burners. Later.
