Adapt midget suspension to rod? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-10-2012, 07:32 PM
Chopt 48's Avatar
Mike Minnet (sp?)out of the Dallas area had quarter epileptics on all four corners of his T bucket in the early 70's and it seemed to work great and maybe better than some of the other suspensions available for similar rods at the time.
There might be an issue if you had long springs or a lot of difference in length between the spring and the upper bar. Most of the ones I have seen use a reasonably short spring that is also fairly flat without a lot of curve to it.
The Following User Says Thank You to Chopt 48 For This Useful Post:
azlogger (11-13-2012)
  #17 (permalink)
Old 11-13-2012, 06:01 PM
Last journal entry: Front suspension update
thank you both. i might just do it that way somehow i like it.
5.7" vs. 6" savman1 Engine 30 01-20-2006 09:17 PM
Rod Length Confusion, Short or Long??? Warrant Engine 11 01-12-2006 02:30 PM
Rod ratio RobbieRat Engine 16 11-29-2005 06:52 PM
Four Bar Rear Suspension in Street Rod sodas38 Suspension - Brakes - Steering 9 08-13-2004 05:40 PM
engine compartment jaxon Hotrodders' Lounge 3 06-04-2004 07:16 AM
