Adapting '49-54 Chev Spindles To Ford Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2011, 10:05 PM
I have a 3" dropped tube axle that takes Ford spindles that I would like to adapt the spindles from a Chevy. I've searched the archives but found very little regarding this adaptation. Has anyone done this swap or know where I can get the info to do it? I know that this was a popular swap done many years ago and Speedway sells axles and the spindles for this. I already have the spindles from a '50 Chev car and want the experience or the aggravation of doing this swap. Any help would be greatly appreciated.
Old 05-10-2011, 11:08 PM
The Ford and the Chevy have different kingpin inclinations. Simply getting the king pin sizes correct does not make the axle usable.
It would be a lot easier, less expensive and time consuming in the long run to just get the proper Ford spindles.
DEUCE ... Moderator
Old 05-11-2011, 07:05 AM
Wiki Edits: 27
spindle swap
50 or so years ago I was running an olds rear end and wanted the bigger olds brakes on the front and match the wheel patern., I took the spindles to a machine shop and they pressed in new bushings then reamed them on the piston pin fitting machinery. Then I had to have the axle bent to get the angle right Sell what you have and match up new pieces you need. . easier and cheaper
Spindles for 28 ford 4"drop tube axle - question 31Vicky Suspension - Brakes - Steering 2 03-26-2011 11:36 AM
adapting old ford spoke wheels speedmill General Rodding Tech 5 10-10-2007 12:48 AM
Adapting ford engine to chevy truck. 68novafan Engine 9 10-11-2006 02:31 PM
Adapting AN fittings to Ford fuel injection Arrowhead Engine 1 03-25-2005 07:40 AM
Adapting a 5 speed transmission to a49-53 ford flathead CARMASTER Transmission - Rearend 3 07-16-2003 12:15 PM
