Adapting AN fittings to Ford fuel injection - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 09:21 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Is there anyway of adapting the stock Ford fuel injection type quick disconnect fuel pump and filter connections to AN fittings? I just want to reuse the stock pump, but run hard lines, not plastic.
I know Summit sells adaptors to go from the stock fuel rail to AN, but then Iím stuck where it connects to the pump.
Any help would be appreciated.
Old 03-25-2005, 08:40 AM
aka Duke of URL
1 -6AN to Ford snaplock fitting - pair Earl's - AN PLUMBING- PN 5700
Give this company's Tech Line a call.
fuel injection ignition Blob Engine 5 12-26-2004 06:15 AM
fuel injection ignition Blob Engine 1 12-25-2004 12:47 AM
Ford spring lock fuel line coupling question dirtlmfan Engine 5 07-09-2003 11:52 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
Ford Bronco and fuel injection cbiggs Engine 2 06-04-2002 01:03 AM
