adaptor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2007, 09:59 AM
adaptor
does anyone know where I can get the dimensions necessary to adapt
a 426 hemi block to a powerglide
Old 02-16-2007, 05:30 PM
69coronet's Avatar
several folks in the following forum are running that setup. a few made their own, some run the tci midplate adapter or JW ultraglide... one of these fellows prob can help you out.
http://board.moparts.org/ubbthreads/...d=Racer&page=0
Old 02-17-2007, 07:43 AM
adaptor
Thanks , I'll look and see what they've got
Old 02-17-2007, 09:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Check with ATI..... they have a new case and removable bell design that I believe is stronger than the JW stuff. ATI bell bolts to the case , not with the pump bolts
engine adaptor seabee 1941 Engine 0 01-07-2006 02:01 AM
Need 9/16-20IFM to AN3 adaptor GregPage Suspension - Brakes - Steering 1 01-22-2005 03:18 PM
Oil adaptor and Starter bolts 39chevy Engine 1 12-26-2003 03:16 PM
T45 Tremec To Ford Late Flathead Adaptor CARMASTER Transmission - Rearend 0 07-08-2003 04:33 PM
Cadillac adaptor? Studebaker Engine 4 07-06-2002 11:10 AM
