-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Add reverse to Singer 111W153? (http://www.hotrodders.com/forum/add-reverse-singer-111w153-224715.html)
udtoy 10-06-2012 09:54 AM
I found a good deal on a nice 111W153 and I'd like to pick it up. I saw a post by DanTwoLakes that mentioned that it may be possible to add a reverse to this machine. Can anyone expound on if this really is possible and if so, how?
DanTwoLakes 10-06-2012 10:31 AM
Yes, it is possible. You need to call an industrial sewing machine mechanic to see what it would cost.
udtoy 10-06-2012 02:13 PM
Thanks Dan - now I know I'm not chasing my tail on something that can't be done... Next question is if it's worth the money for the upgrade, find a 156, or just deal with no reverse...
DanTwoLakes 10-06-2012 04:04 PM
Not having reverse is not a big deal unless you do a lot of sewing. Without reverse, you stitch to the end, lift the foot and re-insert the needle a couple stitches back and then sew over the last couple stitches again to lock the end of the stitch line down.
udtoy 10-06-2012 04:32 PM
I am just starting, so it sounds like I can work without reverse while I practice practice practice. Thanks for your advice.
Coodeville 10-25-2012 12:52 AM
I own a 153. Great machine! Why don't u just go pick up a model that has reverse built into it? Seems to be easier to do than to go through all that trouble.
