Adding aux battery in the back - with a twist - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2010, 09:50 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
So I was thinking the other day. I know, terrible idea. Most vehicles/trucks with a 7-pole trailer wiring harness include a 10ga terminal for 12v+. In my world of towing mostly RVs, that terminal was used by the RV for charging coach batteries, courtesy lights, and other 12v requirements in the trailer.
So, I'm planning on adding a small-ish battery in the cap of my truck since I use it for camping occasionally, but something concerns me. If a battery is capable of dumping 500+ amps all at once for starting, and an alternator can provide up to 100 amps like in my truck, doesn't that mean there is the potential for 100A to be available for "flow" to the secondary battery once you start the engine? How can that happen without frying such relatively small wire?
I want to tie in my secondary battery with the factory rear end harness since the truck has an isolation solenoid as part of the factory setup, but really just a 10ga wire is ok for that?
Old 12-06-2010, 05:25 AM
hi,
you say the truck has an isolation solenoid. how is that solenoid triggered? it may not be connected to an ignition circuit, possibly an accessory circuit? an accessory circuit won't have power during cranking. plus it will probably have circuit protection of some type to protect the wire. what is year, make and model of the truck?
mark
Old 12-06-2010, 06:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
While there is the "potential" for a large current flow to occur, the battery would need to be basically dead to cause the alternator to hit it w/that much current. If the auxiliary battery was being used in conjunction w/the other ('main') battery, I believe it would "buffer" the alternator output to it.
In any event, if there's not already a fuse to protect the circuit, I'd wire one in myself.
Old 12-06-2010, 07:05 AM
bubbahotep's Avatar
In my work car I have an extra batt for accessories when the car is off (fan, chargers, DVD player etc). It's connected to the alt with thinner than 12ga (unrated cheap extension cord wire). I dead that battery 3 times a month entirely and the wire still hasn't fried. It'll pull only as many amps as the batt needs to charge and unless I overload it with accessories I'm not sucking more than a few amps
charging amps is low (30amp??) to the battery which is why it's a small wire from the alt, cranking amp is high, as evident from the fatty wire from battery to starter.
Old 12-06-2010, 07:49 AM
curtis73's Avatar
Wiki Edits: 16
Originally Posted by ween
hi,
mark
98 F150 4.6L
I haven't actually figured it out yet but I'm going to print out some wiring diagrams from Alldata today. What prompted me to check was this: I was towing a little travel trailer with it a few weeks ago and ran the camper's heat all night. When I got up in the morning, the coach batteries were dead. I worried thinking the truck would be dead too but it cranked normally. That prompted me to check, and the B+ pole on the connector only gets juice when the key is on (not sure if its ignition or accessory but I'll check)
Old 12-06-2010, 03:15 PM
curtis73's Avatar
Wiki Edits: 16
Ok, I looked at the wiring diagram (the appropriate page is attached below)
It is a relay that is hot during run. I also have the locations of all the necessary components so I'm going to see what the connections look like, the wire gauge to and from, etc. It looks like it might be a plain-jane 20A relay and 10-ga wire according to the research I've done. What I might do is upgrade the wire to 8-ga and stab in a 30A relay.
... not sure why... other than the fact that I like overkill.
Old 12-07-2010, 01:07 PM
ogre's Avatar
the 'Duracell Project'
your thought proccess is correct, the math does not work, but...
your charge wire off the alternator is 10 ga.
all after market harnesses use a 10 ga wire to the battery with no protection (fuse)
and you are correct; that wire is use for charging a big battery in the tow along
just use it as is.
if you killed the main battery and had a fully charged aux battery you would blow the fuse if you tried to start it.
if you keyed on for a bit, you might be able to flow charge the main battery back
that same wire in my 09 sierra is always hot. no isolation relay.
the factory fuse is (a very expensive) 30 amp slow blow fuse
killing an rv battery would also kill my main battery
i use that wire to power a scooter lift and do not need the key on
where is doc vet when you need him... rip doc
Old 12-07-2010, 05:41 PM
SSedan64's Avatar
I installed 8 gauge wire with a 40amp self resetting Circuit Breaker on the Aux. on mine.
The Brake + called for 30amp breaker w/10 gauge.
Old 12-08-2010, 11:11 PM
curtis73's Avatar
Wiki Edits: 16
I'm going to pose a theory from my limited grasp of the subject....
Could it be that batteries with their potential for large amperage out are because the load has no voltage?
I'm thinking of it this way. A battery has 13v of "pressure" out to the load, so between the battery and starter you need a cable of sufficient cross-section to carry the amperage. But, going the other way, the alternator is only providing slightly more voltage than the battery, therefore reducing the load.
The voltage differential between the battery and the starter is 13v to 0v. Recharging even a dead battery, the potential between the alternator and the battery is from 14v to 10v thereby reducing the amount of potential amperage that actually charges the battery.
In this way (by my amateur theory), its like draining a large water tank from the bottom... its capable of venting large volume and pressure, but then if you try to feed water back through the drain, it doesn't refill nearly as fast as it drained because you are fighting the weight of the water (the voltage of the battery.)
So, while a 100A alternator can provide 100 amps at peak, charging a battery would only require a small portion of the electrical load since its fighting the voltage "pressure" of what's left in the battery.
Does that sound plausible, or am I just pulling stuff out of my anus?
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
Starter keeps starting and battery exploded Huug Electrical 13 10-06-2005 05:48 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
