Adding capacity to improve cooling system? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2011, 12:33 PM
Just thought I"d run a silly thought by you all.
My current system is pretty much maxed out on 100+ degree days. I like my radiators fitment and I'm within a half inch of hitting the crank pulley as it is. (no room in front either (intercooler). I was thinking of adding a 1-2 gallon additional reservoir inline with the cooling system to help it out a little? Haven't really ever heard of this being done. Anyone try it?
Old 07-12-2011, 12:42 PM
Have you considered adding an oil cooler. Adding a resevoir of extra coolant wont cool any better unless the resevoir has some way of cooling the 2 gallons of coolant with it.
Old 07-12-2011, 12:57 PM
I suppose your right, would just take a little more time for it to get to it's peak temp. I was comparing it to a boiling a cup of water compared to 3 cups of water.
Yanno I had an oil cooler installed last year and I switched over to e85 and eliminated it this year. I may need to put it back on. Oil temps with my temp gun were around 170-180 after a pass. I didn't think it would make that much difference. Thanks for the tip...
Old 07-12-2011, 12:58 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
An oil cooler can make a big difference in removing engine heat..
Sam
Old 07-12-2011, 04:01 PM
ALSO ...
a extra transmission cooler ... placed in line between the transmission and the radiator can HELP reduce engine temperatures.
I also have a extra transmission filter on my cars. It adds about a quart of fluid and keep any trash from the coolers and the transmission pan.
Old 07-13-2011, 07:01 AM
Yes, when added to the same container, it would take longer to warm up. But youre talking about adding a seperate container, and unless that container is designed to remove heat from water, it wont help cool the car. Does the car have a heater system. If not, you could plumb in a large heated core, vent it outside the car so the interior doenst get hot, add a fan to force air over it.
Old 07-13-2011, 07:31 AM
Wiki Edits: 27
back in the day
I remember driving truck, from Carson City Nev to Lake Tahoe, Calif. Fully loaded up that steep road, We had the heater on full blast and the doors proped open with a piece of broom stick. 4 hours up, 17 minutes back down. I had a friend that raced a datson 2000 roadster. He added an old truck heater box with a fan under the hood with hoses routed in line. It cost him $ 15 and added enough cooling capacity.
Cooling capacity of a 350 Chevy block Arley Hotrodding Basics 9 02-29-2012 08:13 AM
Adding Overflow Tank to Cooling System JohnTN General Rodding Tech 4 06-15-2010 05:56 PM
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 07:34 PM
cooling system Capacity chevyguy86 Engine 5 11-04-2005 10:34 PM
Cooling capacity red34ford Engine 2 05-24-2005 04:00 PM
