-   -   Adding coats of clear coat......... (http://www.hotrodders.com/forum/adding-coats-clear-coat-186296.html)
labreejr 10-19-2010 06:14 PM
I painted the interior of my Cutlass to match the exterior about a month ago. Came out just how i wanted it, sprayed 1 coat of clear. My question is, what prep work do I have to do now if any to spray an additional 1-2 coats of clear? Can I just wipe with a tack cloth and spray?
cyclopsblown34 10-20-2010 11:17 AM
I'd suggest scuffing it with a scotch brite and then tack it and reclear.
joe_padavano 10-20-2010 12:07 PM
Rather than guessing, get the manufacturer's spec sheets for the specific brand and type of clear that you used. Requirements are different for each manufacturer. The spec sheets for most major paint manufacturers are available on-line as PDF downloads. Read them and follow the instructions.
shine 10-20-2010 01:19 PM
sand with 600 then reclear.
