Adding coats of clear coat......... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2010, 07:14 PM
labreejr's Avatar
I painted the interior of my Cutlass to match the exterior about a month ago. Came out just how i wanted it, sprayed 1 coat of clear. My question is, what prep work do I have to do now if any to spray an additional 1-2 coats of clear? Can I just wipe with a tack cloth and spray?
Old 10-20-2010, 12:17 PM
cyclopsblown34's Avatar
Colorsanding painter
I'd suggest scuffing it with a scotch brite and then tack it and reclear.
Old 10-20-2010, 01:07 PM
Rather than guessing, get the manufacturer's spec sheets for the specific brand and type of clear that you used. Requirements are different for each manufacturer. The spec sheets for most major paint manufacturers are available on-line as PDF downloads. Read them and follow the instructions.
Old 10-20-2010, 02:19 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
sand with 600 then reclear.
Not enough clear coat? nickt93 Body - Exterior 8 05-07-2010 03:28 PM
Metallic Chromabase questions Noob81 Body - Exterior 13 04-15-2010 04:10 PM
Just how much does clear "fill", a little test I did. MARTINSR Body - Exterior 26 10-28-2009 09:31 AM
Eliminate filler pinholes with dental pik and credit card cboy Body - Exterior 8 05-21-2009 06:48 AM
Time between Clear coats TurboS10 Body - Exterior 11 11-23-2002 05:55 AM
