Adding compressor storage tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2011, 05:21 AM
First off, i'm not adding the tank for extra air capacity. The main goal is to help remove moisture. I have my old CH 26 gal tank i could use. What i'm looking for, is the proper way to plumb this into my system, while it being safe. Does the storage tank need a pop off valve? Anyone have a simple diagram to plumb it in?
Old 05-07-2011, 05:48 AM
As long as the tank is rated to at least the same pressure as the main tank a relief valve is not necessary, the valve discharge rate has to exceed the pump CFM rating and tank volume doesn't matter. As for what you want it for that will work unless the compressor is too small, I would not add more than about 20% to the original volume and certainly no more than 25%. if the compressor is a large one with a 100% duty cycle this is not going to be nearly as critical. The cooling tank ("Thump tanks" is what we called them) should be plumbed into the system well downstream of the main tank for best results, plumbing in really close will largely negate the benefits. Then the "in" supply pipe should be near the bottom of the tank with the take-off point at the top, it is best if the air enters from the side near the bottom and not directly up from the bottom. In any case use ONLY existing fittings /ports on the tank and never attempt to weld extra ports to the tank, one of the catastrophic ruptures I saw was because of doing this. Basically never weld on a tank for any reason.
Old 05-07-2011, 08:21 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
^^^^^^that pretty well covers it
Old 08-01-2011, 07:21 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Matt got a new motorcycle.
Try building and using this. Works very well to remove moisture.
http://route60garage.blogspot.com/20...anzinator.html
Storage Tank for Air Compressor? jcorey2293 Garage - Tools 11 02-03-2010 08:22 AM
Proper storage of AC compressor? KenCam Engine 4 05-03-2007 10:17 AM
compressor storage montea Garage - Tools 2 12-26-2006 10:22 AM
adding on a extra compressor tank ikeaguirre1414 Garage - Tools 7 09-13-2006 05:34 PM
Adding 2nd air tank to compressor cboy Garage - Tools 7 10-26-2004 10:17 PM
