Maybe, if you have a wiring diagram for the column and the unit.
I have found that aftermarket CC units are crap. Maybe, you can adapt a factory one.
Ontario Rodders |
John,
I put an Audiovox Universal Cruise on my '32 and I'm very happy with it (especially considering the $90 price tag). It has button controls (not a stalk/lever) which I mounted in an inconspicuous spot below the dash. I have 9,000 miles on it and haven't had any problems. The only drawback I can see is that the installation sheet is not very good and I had to search out a couple sites on the web to that sort of walk you through the installation and calibration of the unit. BTW, for some additional bucks you can get a stalk mounted control switch.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
I agree with Ponch, most if not all aftermarket CC's are garbage. I would adapt a late model GM unit to the street rod. The criuse in my 90 Chevy full size truck is all electronic, with zero vacuum lines. It has been bullet proof since new. When I finish my 34 I will be looking at that model truck for a cruise control. I would stay away from the later models as they interact with the VCM (vehicle control module) too much to be adaptable to a street rod unless you are running the engine and trans that the VCM is controlling.
Vince |
Aaaaaaaaaaay, you callin' my cruise control junk? Put up your dukes.
Dewey
Not to worry. There are a lot of people who would agree with you about the aftermarket cruises. My personal opinion, at least about the Audiovox, is that they would have a much higher percentage of happy customers if they would spend some time to write a decent installation/troubleshooting manual.
I think it would be an easy matter to adapt a 90's model Chevy truck cruise to a streetrod. the cruise on my truck is one box. You could use a speedo trigger for an electronic speedo from AutoMeter or VDO and tie it into the GM cruise control. I think it would make a sweet installation.
Vince |
I dunno if I would knock all after-market units. Over the years I have installed several vacuum types with varying degrees of success, but for my current project I purchased and installed a Global Cruise Rostra all electronic unit...
http://www.rostra.com/cruise-control.htm While I cannot vouch for how well it works since I am not on the road yet, what articles I have found all say good things. The instructions were easy to understand (never got that "these instructions have been poorly translated from some other language feeling"). The controls are on a (good looking) wand that I installed on my Ididit column as the turn signal control (fishing the wires down to a hole I drilled was not my favorite sub-project). It is quite a bit more expensive that the vacuum units (which is probably a good thing). Last spring I purchased and installed an Audiovox unit on my motorcycle. Installed 2 magnets on the rear wheel for the pick up. Couldn't get it to kick in below 35 mph. Called the tech line. The guy was very rude and just looking for a reason to get rid of me. At first I was vague about what it was installed in. Finally told him. Waa-Laa, now he had his reason to get rid of me, which he did. Ain't no difference between my installation and magnets on a drive shaft. Anyway, wont be buying anymore of their stuff. |
I installed one of those 80s GM vacuum operated controls with the remote pot metal case that two speedo cables go into on my buddie's '42 Willys truck. Beauty of this unit is the control is 1 inconspicuous button in the end of the turn signal. There are no markings whatsoever so unless you know it's there, you have no clue the truck has cruise. Had to check out a dozen or so control units at the junk yard to find one that didn't have spun/frozen bearings on the internal workings. But we finally found one that looked good. We hid the box back under the bed of the truck near the speedo shaft on the tranny so there is zero evidence inside or outside the truck that it has speed control and it has worked perfectly for many miles over the last 12 years.
Willys,
All units I can remember typically have... set/coat, resume/accel. on/off. With only one button whats the deal, just 'set/coast'? |
I don't recall all the protocol but it has all the features. As I recall, quick tap sets it, hold the button down accelerates, maybe double tap and hold second tap coasts, tap the brake pedal turns it off. Anyway, it is a really neat setup and best of all comes pre-installed in a stock GM column from the junk yard and you know how much I love getting parts from the junk yard! Here is the column installed in his truck. Photos don't show the button unfortunately.
First unit I had was a Audio Vox, mounted it on a Model A. For those of you who are familiar with the A, there isn't much room under the dash, so I had to go under the car, being a Roadster I don't drive in the rain if possible so I thought I would be safe. Worked fine for about a year then it would engage but after a couple of miles it would drop out, tried everything finally took it out and replaced it with a Global all electric, that has never worked, lights are on but no one's home, anyone have any ideas let me know.
Thanks Jim |
I have installed several of the Audiovox units with no problems so far. Instead of the magnets on the driveshaft, I use a Ford inline speedo cable signal generator. Ididit has a turn signal switch with the cruise buttons built in that will work with the Audiovox cruise, it will also work with the Rostra cruise.
If you have an electronic speedo, that will give a signal for the cruise too. The old GM cruise is good too. Only Oldsmobile and Caddy had the resume feature, the rest had to be reset every time. I have installed the late GM cruise in several cars, but always with EFI engines. They are particular about the signal they receive, the aftermarkets ones will work with a sine wave generator, the GM cruise needs a square wave signal. Painless makes a signal generator that will work, but it's $85. Otherwise they will work fine with a carbureted engine. You do need a tach signal too. |
