Adding electronic cruise control - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2013, 09:07 AM
Hope I can get some input on this. I have an '07 5.3 take-out in a '39 Ford which is on a S-10 chassis. I would like to be able to use the newer cruise set-up. I think I will have to add wheel speed sensors. Has anyone done this yet? Thanks, Steve
Old 09-30-2013, 12:45 PM
you can get a speed sensor that drives off of your speedo cable
Old 09-30-2013, 05:21 PM
LATECH's Avatar
That cruise control doesnt use a cable driven anything.
The necessary hardware is in the trans and the pcm , along with the throttle body, if it is drive by wire.
The wheel speed sensors only come into play with ABS and traction control.The necessary sensor is allready in the trans, as long as you are running the engine /trans from the donor and are using the PCM
Fact is stranger than Fiction
Old 10-01-2013, 09:06 PM
Thanks, I have all the stock parts with this set-up. It's down the road before I tackle the cruise portion but if I needed sensors on the wheels I would have to address that now. Steve
Old 10-02-2013, 02:37 PM
ogre's Avatar
the 'Duracell Project'
i have a rosta global cruise control in my 58. it is a kit that uses a speedo cable driven pulse generator to check the speed. the kit is an all in one box with a cable for the throttle pull sticking out. they have a variety of on/off/set switches, since i have a typical gm tilt column, they inclused the correct multifunction switch lever to match my column.
Old 10-02-2013, 04:35 PM
Banned
who sell that?
Old 10-02-2013, 09:23 PM
evolvo's Avatar
Contact Rostra Precision Controls, Inc.
Old 10-03-2013, 06:25 AM
Irelands child's Avatar
When you finally get to looking into it, almost all of the after market cruise controls are made by Rostra - including Dakota Digital, IDIDIT and Flaming River. These work very nicely (I have one on my '31) though the installation instructions leave a lot to be desired and will take a couple of hours to figure out.This may be a better choice then trying to cobble something together from a donor car where you may not have gotten every needed piece.
Irelands child
Old 10-04-2013, 11:23 AM
ogre's Avatar
Originally Posted by gearheadslife View Post
who sell that?
everyone
look around for the best price, lot's of vendors carry them under their own brand too.
Old 10-04-2013, 06:37 PM
spinn's Avatar
where does the pulse come from? is there a junction box in the speddometer cable?
This looks nice. Does it work with a supercharged setup? Being electronic it should.
Old 10-05-2013, 09:27 AM
Most cruise controls only have two unique items to configure, (1) how to measure speed and (2) how to pull the throttle without affecting normal throttle operation. Supercharging, turbocharging or whatever, it usually does not make a difference.
Modern cars have vehicle speed sensors that provide input to the cruise control, but they are usually not at the wheels. The sensors at the wheels are for ABS, traction control, tire pressure monitoring, etc. If you can find the VSS output from your transmission (usually just an electrical plug with a couple of wires), you may be able to use that directly.
If you need to add a VSS, its usually easiest to add it in the speedometer cable, but there are other alternatives. On the old cruise controls you put magnets on the driveshaft and mounted the sensor within about 1/2" to measure the speed. If you didn't get the magnet glued on real well they might fall off, but other than that it seemed to work okay. You can still buy this type of sensor.
You may also need adapters to connect the cruise control to the throttle mechanism. Many times they use a beaded chain for the last few inches of the cable so that you can let the throttle move back by lifting your foot off the pedal, and it won't push back against the cruise control. You don't want the cruise control make the throttle bind.
It should also have brake pedal cutoff and may have a tach signal connection. If its all electronic there should be no vacuum connections; however, the old ones used to use a vacuum actuator to pull the throttle.
Bruce
Old 10-05-2013, 11:08 AM
spinn's Avatar
After adding the large body of the roots on top, the cruise rod had to be bent upwards. This caused sticking at points. That is the reason I mentioned that condition.
Old 10-05-2013, 05:03 PM
ogre's Avatar
yes it has a junction box on the end of a 12'' speedo cable.
i don't see a supercharger affecting cruise.
Cruise control jbbob Electrical 1 05-21-2013 04:24 PM
cruise control vatosteve Hotrodding Basics 1 04-30-2012 11:41 PM
cruise control pizzaman General Rodding Tech 0 11-16-2010 01:13 AM
Adding Cruise Control to Street Rod JohnTN Electrical 36 03-26-2006 06:50 PM
700R4, cruise & electronic speedo 302 Z28 Transmission - Rearend 10 10-31-2003 01:28 PM
