Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Adding grease to upper ball joint
Old 12-06-2012, 11:00 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
I agree with Poncho62 that the ball joint casing is cracked...The ball joint is not pressed in it's bolted in (the tree bolts beside the joint). In my opinion the ball joint should be replaced, I don't see an immediate safety issue but if it in fact is cracked...replace it.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
tomkeechi (12-06-2012)
