Adding grease to upper ball joint
I installed new control arm ball joints on my 1960 Tbird. The top ball joints wouldn't take any grease. After exerting a great deal of pressure
the grease started coming out the top near the grease fitting but won't get to the ball itself. I've attached a photo. Anyone have any ideas? It happened on both upper joints but not on the bottom. |
If that is a pressed in ball joint, it seems to have a split case........it looks to be crooked in there
Ontario Rodders |
| The Following User Says Thank You to poncho62 For This Useful Post: | ||
tomkeechi (12-06-2012) | ||
Did U try different greese fittings? It's not unusual, even for new zerks, to be frozen up.
| The Following User Says Thank You to Trophyman For This Useful Post: | ||
From that pic, it looks like the zerk is fine, but is leaking out around the ring that holds the ball joint together. I would jack the car up, let the wheels hang and apply grease.....it might go in easier that way
Ontario Rodders |
Thanks a lot. I'll try that. |
| The Following User Says Thank You to 69 widetrack For This Useful Post: | ||
Maybe "cracked" is the wrong wording...it looks like the top of the ball joint has the seam letting go from the main body of the ball joint.
Sorry about that, thought about it and figured I worded it wrong. Ray |
Yes, I've tried 2 new fittings. Thanks
| s10 ball joint/ 4runner ball joint | stevetankl | Suspension - Brakes - Steering | 1 | 06-16-2012 01:59 AM |
| 68 gto ball upper ball joint removal question | adam83 | Suspension - Brakes - Steering | 25 | 01-04-2011 01:39 AM |
| Upper Ball Joint Trouble | Camaro_Nut2001 | Suspension - Brakes - Steering | 3 | 05-15-2010 10:05 AM |
| Nova upper ball joint zerk fitting | 68NovaSS | Suspension - Brakes - Steering | 2 | 07-18-2006 10:46 PM |
| upper ball joint boots | yezek6 | Suspension - Brakes - Steering | 3 | 03-29-2005 04:25 PM |
