Adding height to the front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2006, 09:24 PM
I added a 454 to my 80 Camaro. The problem is that the front end is now setting several inches lower and I am having clearance problems! Is there a set of springs that will raise it up a few inches? Jegs says they don't have anything like that!
Old 07-21-2006, 09:36 PM
Wiki Edits: 31
what you need are a set of big block springs, I'm not shure if a '80 Camero was offered with a big block but you could go to your local parts store and tell them what you got and they should have a stiffer spring to work
Old 07-21-2006, 09:40 PM
Kallie49's Avatar
heck if your in Ohio your in Summit Racing country (they are in Tallmadge I believe) and dirt track country....I'd hit up some of the ma and pop dirt track shops and see what they can dig up thats a real popular front end for the super stock roundy rounders....
Old 07-21-2006, 09:45 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You need a set of big block springs.
Chevy truck Tilt front End! Onestophotrodshop Body - Exterior 0 12-01-2005 12:26 PM
Front end mock up shows some problems, cut n weld or frame shop? Ripped Body - Exterior 9 11-26-2005 08:03 PM
front end problems tonylsg Suspension - Brakes - Steering 13 04-15-2003 07:47 PM
Mustang II front end Question horvath Suspension - Brakes - Steering 35 03-02-2003 05:08 PM
is there any front end alignment people out there? IHAVECHEVYPARTS Suspension - Brakes - Steering 5 11-26-2002 08:10 PM
