Adding an oil temp gauge to SBC - how to? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 09:55 PM
Hi all - I'd like to add this type of oil temp gauge to my SBC.
temp gauge
Is there a place on a SBC to put a temp sensor/sender?
If so, where is it, and what are the thread specs?
thanks!
Old 03-28-2006, 10:14 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Why? If you must, weld a collar in the oil pan sump to screw the sender into.
Old 03-28-2006, 10:51 PM
Does anyone know the thread specs for the oil pan drain plug?
1970 El Camino SS Oil Pressure Gauge retrotruckparts Electrical 2 10-19-2005 07:08 PM
Oil Preshure ve3ham Engine 9 10-28-2004 02:36 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 12:47 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
Oil pressure Gauge rehjr0219 Electrical 1 02-22-2003 07:54 PM
