Adding Overflow Tank to Cooling System - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2010, 02:50 PM
I have a Walker Radiator in my '39 Olds street rod. It has a 12lb cap and the overflow discharges to the ground.
Can I just add an overflow tank to the overflow hose and have a closed system?
If I add one, I don't see how the coolant can be sucked back into the radiator as it cools down. The overflow nipple is above where the cap seals down on the the lip of the fill neck.
Will I need a special cap or do all caps have a way to let the coolant be sucked back in?
John
Old 06-15-2010, 02:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yes you can add one to your set-up, What i did was bought one from jegs and it is for either way just a over-flow or it can be hooked up to recirculate the coolant back to the radiator. Here is what i am using , http://www.jegs.com/p/JEGS/JEGS-Hexa...56127/10002/-1 . It comes with the vent for the top and the fitting for the bottom to hook your hose to and then it will recirculate.
Cole
Old 06-15-2010, 03:11 PM
That looks like a basic overflow tank similar to what I have bought. Just don't understand how the coolant gets back into the radiator past the pressure cap.
Haven't installed mine yet to see if it works by magic somehow.
John
Old 06-15-2010, 05:26 PM
Joe G's Avatar
Originally Posted by JohnTN
....Just don't understand how the coolant gets back into the radiator past the pressure cap.
As the engine cools off after shutting it down, the coolant cools and contracts which creates a slight vacuum. There is a small check valve in the center of the radiator cap that allows coolant from the overflow tank to be sucked back into the system when this happens.
Old 06-15-2010, 05:56 PM
Ah ha! Thanks Joe.
John
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 07:34 PM
Preventing air in cooling system. BMM Engine 3 09-21-2008 08:39 PM
Cooling System (Way Too Much Pressure) ??? white66coupe Engine 16 07-31-2006 05:51 AM
Adding gas tank outlets syborg3D General Rodding Tech 1 02-03-2005 07:49 AM
Overflow tank question Jag Daddy Engine 8 02-03-2004 10:26 AM
