Adding pressure/temp gauge for T-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2009, 12:51 AM
Hi,
my name is Daniel from germany. I got a lot of good tricks from this board in the past.
At the moment I want to add an oilpressure and oiltemp gauge for my TH350. Has anybody an good idea where I can put the sensors at the tranny? Or is there a testhole or something like that where I can put it in.
Daniel
Old 07-08-2009, 12:43 PM
SSedan64's Avatar
This site shows where you can connect your pressure gauge to (Line Pressure) port on right side of the trans. > http://th350.netfirms.com/browser.htm
Most weld/braze a pipe fitting bung to the pan for Temp sensor. Some install them inline one the trans cooler (out) line but, this method will give a higher temp reading as the fluid comes from the torque converter.
Old 07-08-2009, 02:04 PM
XNTRCI-T's Avatar
AKA Lee in KC
For the temp sensor in the pan, I just drilled a hole through the side of the pan just big enough to clear the threads on the sensor, put a nylon washer on the sensor, inserted in the hole, then screwed an NPT reducer (with another nylon washer) onto the sensor like a nut, from inside. Of course, the pan has to be off to do this.
Old 07-08-2009, 02:43 PM
That is very helpful for me. Thx...Daniel
Old 07-08-2009, 07:24 PM
XNTRCI-T's Avatar
AKA Lee in KC
Daniel, this is what I mean by a reducer. If you can't find one on your side of the pond, let met know and I'll send you one.
Old 07-08-2009, 10:42 PM
Hi Lee,
I know my parts-dealer has this reducers. But till now I didn't know what to do with such an crazy thing. But your idea is great. I will try my luck with a reducer. Thank you.
Old 07-09-2009, 08:01 PM
boatbob2
a question,
hi,how far from the bottom of the trans pan,should the sensor hole be??
Old 07-09-2009, 11:45 PM
SSedan64's Avatar
As long as the sensor is covered it doesn't matter. Center of pan side is good. Make sure the sensor doesn't interfere with anything inside pan also.
Old 07-10-2009, 06:38 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Try not to block a pan bolt with the sensor... it makes getting a tool onto the bolt head difficult.
Need help with temp and oil pressure gauge 0pyders Electrical 4 06-30-2012 12:21 AM
oil temp gauge instead of trans temp gauge mocheez Electrical 8 01-01-2012 01:02 PM
350 sbc temp/pressure units 1969chevyss Engine 13 08-20-2011 07:58 PM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
Adding an oil temp gauge to SBC - how to? Porchev Engine 2 03-28-2006 10:51 PM
