Adding a Second Battery - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-02-2010, 11:11 PM
If it was me doing this, I would get a solenoid isolator, basically a continuous duty starter solenoid, mount it on the inner fender near the secondary battery, run a ground wire to a good ground from the secondary battery, run a hot positive 2 to 10 guage wire from the secondary battery to one side of the solenoid, a 2 to 10 guage wire from the other side of the solenoid to the primary batterys positive terminal, run a smaller wire from a hot ignition-on terminal to actuate the solenoid when the key is turned on, and call it a day.
  #17 (permalink)
Old 09-04-2010, 10:33 AM
The mobile view is crap
if i set it up this way and wire the winch to the second battery will i be able to kill the first battery?
  #18 (permalink)
Old 09-04-2010, 10:39 AM
http://www.summitracing.com/parts/PRF-40102/
maybe something like this?
  #19 (permalink)
Old 09-04-2010, 05:40 PM
All sorts of ways to go about this, and every single one always has one or more significant disadvantages to it.
Another approach altogether which is entirely safe would be to fit a second alternator to charge the second battery, and leave it totally separate from the existing vehicle electrical system.
This has been done many times for campers, off road, and the high power car audio people.
You can run that sucker right down to zero, and there is no way it is going to immobilize your vehicle.
  #20 (permalink)
Old 09-04-2010, 08:17 PM
59 wagon man's Avatar
did the "perko" switch years ago on my blazer never had a problem .did it for the same reason
home made battery charger lanier ledford Electrical 9 08-29-2010 01:57 PM
battery cables corvettetonybone Electrical 31 04-07-2009 06:07 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 09:33 AM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 04:01 PM
Spacers behind fan? moodier General Rodding Tech 14 10-06-2005 09:08 AM
