Originally Posted by ogre
i thought the panels had the same structure inside as the suburbans
if that's the case try to get suburban windows and trim to fit in there
Actually the panel and the burb are quite different under the skin. The entire floor in the panel is different. On the burb it has a rear door on the passenger side and the drivers side basically has the structure of a rear door beneath the outer skin. roll down windows and such. Ive seen several opened up and made into a usable door. Not easy, but doable.
So the windows wouldn't match up ( I checked this first ), plus the angles are off If I was to make flush fit openings for them.
Hindsight is 20/20 of course, I used to have a couple of burbs of that era ... shoulda kept them and let the panel go down the road =)
