Adding windows where there were none .. flush fit - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-20-2012, 04:49 PM
This is the only way I can imagine you could do this without paint. Get a window and make a channel that would go around the window. Cut a hole in the body the same size as the channel, we are talking PERFECTLY cut it out and grind it out to the perfect point. Glue the channel to the back side of the metal with structural bonding adhesive. (YES it would be strong enough) And then set the glass on urethane in the channel and use a moulding like on an 80's S-10 Chevy or Camaro of the vintage. The moulding simply tucks into the channel between the glass and the channel sealing over the gap between the glass and the channel.
You may be able to pull this off without damaging the paint.
Best idea yet!
  #17 (permalink)
Old 08-20-2012, 07:18 PM
Originally Posted by ogre View Post
i thought the panels had the same structure inside as the suburbans
if that's the case try to get suburban windows and trim to fit in there
Actually the panel and the burb are quite different under the skin. The entire floor in the panel is different. On the burb it has a rear door on the passenger side and the drivers side basically has the structure of a rear door beneath the outer skin. roll down windows and such. Ive seen several opened up and made into a usable door. Not easy, but doable.
So the windows wouldn't match up ( I checked this first ), plus the angles are off If I was to make flush fit openings for them.
Hindsight is 20/20 of course, I used to have a couple of burbs of that era ... shoulda kept them and let the panel go down the road =)
  #18 (permalink)
Old 08-20-2012, 07:23 PM
Originally Posted by Old Fool View Post
Best idea yet!
Yes, I agree, but I also appreciate every ones input. Ive been a member here for a year and never had a reason to ask any questions, and when I finally did I got a bunch of great answers.
Today I contacted a master fabricator in our area and he said when I am ready bring the panel on down and he would work with me on the project. I need to get a hold of my glass guy to make sure he is good with doing it this way. Personally I think it will look fine.
  #19 (permalink)
Old 08-20-2012, 07:51 PM
sparkydog's Avatar
Spa Mercenary
Last journal entry: Updates July 2012
I'm not sure if the SHAPE of these windows is what you have in mind but in terms of a nice flush fit and look.... IMO the side windows of a more modern Burb or Astro van might work for you.
  #20 (permalink)
Old 08-20-2012, 08:18 PM
I checked a bunch of the more modern windows and they are too tall =(
  #21 (permalink)
Old 08-20-2012, 08:28 PM
what is the dimensions of the side of the panel truck i might be able to find a factory window that might work for you
  #22 (permalink)
Old 08-20-2012, 11:39 PM
put up or shut up
That would look super, Martin.
been wanting to get a shrinker/stretcher. They'd be helpful around here.
I forgot about that tool cause I don't have it and keep telling myself to get one.
Might order the eastwood pair soon.
  #23 (permalink)
Old 08-21-2012, 08:47 AM
I appreciate the offer, but Im going to want them to fit the body lines of the panel exactly so I will have them custom cut.
For God's sake it is FIT, FIT, not "Fitment" when you are talking about panel fit. MARTINSR Off-Topic 52 09-08-2009 08:52 AM
Flush mount windows EastCoastSBC Body - Exterior 2 06-24-2007 09:26 AM
flush keith denson Introduce Yourself 1 07-11-2005 04:35 PM
1929 model a two door sedan - Flush Fit Doors jastreitz Body - Exterior 0 04-29-2003 11:39 AM
flush mount windows CARGUY Body - Exterior 2 04-15-2003 09:28 AM
