additives - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2014, 11:34 AM
additives
Has anyone used additives in an automatic transmission to eliminate slippage?
Old 07-20-2014, 11:44 AM
Banned
all are bandaids, start saving
Old 07-20-2014, 03:24 PM
poncho62's Avatar
Wiki Edits: 5
I was getting a component slippage code in my 97 4L60e trans (code p1870).....Turns out the trans was overfilled and the fluid was foaming. We changed the fluid and filter. Added a can of Lucas Trans Fix. It has been good ever since......Not saying the Lucas helped or not, but my mechanic suggested that it wouldnt hurt
Old 07-20-2014, 07:20 PM
With a tranny, if you think you have a problem, check the fluid level first. Then check the fluid color and smell. Should be a nice clear looking red, and not smell burnt or funny. If its not any of those, you need to drop the pan and change fluid and filter. Even then you can't get it all out. I wouldn't think a little additive wouldn't hurt, but remember, they can't cure a problem. They may help soften up the seals to slow the leaks, but I'd have to agree, start saving some money, because your about to spend some on a rebuild.
e85 additives? ap72 Engine 1 02-05-2012 12:17 AM
OIL additives Gladis Engine 14 11-04-2007 08:00 AM
fuel additives byrdta76 Engine 7 06-12-2006 09:59 AM
Oil additives? 5.0Towncar Engine 4 11-20-2002 06:35 PM
Additives - Yes or No!! Jim Weeks Hotrodders' Lounge 4 06-12-2002 06:13 PM
