adheasive promoter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2004, 08:45 PM
jefrohunter's Avatar
New Member
Red face adheasive promoter
Hey ! Im glad to be part of this finally. My son has a 86 firebird and it has been painted 2 time before he got it and both times the paint came off the front and rear . Both of these are plastic.I am just starting to paint cars and my exp. is limited . My question is can i use adhesive promoter on entire car, I dont mind the exspence?
Old 03-12-2004, 06:12 AM
Wiki Edits: 49
Flexible parts such as plastic, rubber and in some cases fiberglass should have a flex agent added to the paint before they're sprayed. Paint once dry will be somewhat rigid and over time the flexing of those parts will cause the paint to delaminate or lift and then peel. Just add the recommended amount of flex agent (based on the "P" sheet for your particular paint) and you should be fine.
Centerline
Old 03-12-2004, 09:00 AM
adhesion promoter is always a good idea. I use it in my shop all the time just to be on the safe side because when you do expensive custom paint jobs the last thing you want to worry about is it flaking off. As far as plastics go, you have to get a plastic cleaner, plastic compatible primer, and a flex agent
Old 03-12-2004, 09:39 AM
New Member
thanks Iwould like to do some custom work on his car and I dont want to do it twice. Plus it a rolling advertisment for me with the younger crowd. Again thanks .
Old 03-12-2004, 10:55 AM
New Member
I planned on using a flex agent. Should I use the adhesive in the primer and clear? should I use flex in claer as well?
Old 03-12-2004, 05:47 PM
astroracer's Avatar
"Adhesion" promoter is sprayed on the part prior to spraying paint. It is not mixed WITH the paint... I have never used adhesion promoter when spraying plastic parts but everyones habits are different. I believe if the parts are cleaned and prepped correctly the adhesion promoter is not needed. I have never had any problems with paint peeling or flaking off plastic or urethane parts.
As far as mixing in flex agent I believe the agent gasses out in 30 to 60 days and is just used for assembling the parts to the car... Am I wrong? That is what my jobber told me so, if the parts are still on the car and aren't going to see much flexing I don't use flex agent either...
I would recommend having a heart to heart with your paint supplier. A lot of your questions can be answered by him and they will vary with whatever paint manufacturer you decide to use...
Mark
Old 03-12-2004, 06:06 PM
apply the flex in both the primer and clear or anything that is going to flex.
Old 03-12-2004, 06:21 PM
New Member
thanks guys you have been a big help. Also Im using PPG primer,paint,and clear. Everyone I have talked to said it is the best product for the money.
Old 03-12-2004, 06:24 PM
astroracer's Avatar
Read this... http://www.collision-insight.com/news/20030307-scrs.htm
then go talk to your paint supplier...
