Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Adheision test.
Thread: Adheision test.
Old 04-08-2005, 06:31 AM
baddbob baddbob is offline
The DBU500 is more of an intercoat clear than a blender but it can be mixed with DBU color to lessen the strength for blending. DBC500 is very similar, and Global D895 is also similar. Most people when blending problem metalics will apply a coat of this transparent base over the complete panel then blend the color into it. This avoids metalic hangup in the sandscratches. Since these three products are basically just transparent basecoat I'm sure the adhesion with them would be the same as if you were just coloring the complete panel. Dupont's 222S has also been used for the same function since the days of laquer. The DBU500, DBC500, and D895 can also be used for checking color match when a quick coat of clear is needed.
