Adhesion promoter - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2007, 02:30 PM
Adhesion promoter
How does adhesion promoters like "Bulldog" work? Are they any good for bare steel? I am talking about for use on small brackets and such not under BC/CC paint on a body part. I know how etching primers and epoxy work but I was wondering how the Bulldog type products help with adhesion and what it is that makes them different from other primers.
Old 10-13-2007, 06:32 AM
BarryK's Avatar
Depends on the adhesion promoter, if it is a Chlorinated polyolefin the adhesion is chemical, this is the most popular for use on TPO and TEO type plastics due to their low if any, surface charge.
Silanes, are sometimes used for plastic adhesion but not as often and used for for adhesion to glass, metal and specialty metals and normally incorporated in the epoxy or 2K type primers.
So the answer is a Silane type may be good or may not but why gamble and try to reinvent the wheel? You know and have epoxy/acid etch products you have been using and know what they are made for.
The only proper way to know if your idea is better is to do an adhesion test with an adhesion tester with and with out.
Old 10-13-2007, 09:53 AM
The reason I was looking at using this stuff is that it would be very convenient to have a rattle can type primer for use on small non-critical parts. Case in in point-a fuel pump mounting bracket along with a filter bracket. These parts are small and normally out of sight and would be of little significance but I certainly would not want the paint to flake and allow them to rust plus they will be seen occasionally and would detract from the otherwise clean appearance of the undercarriage if they looked bad. I just thought that if this stuff worked ok it would just be handy to grab a rattle can instead of mixing a small amount of epoxy, etc and then having to wait for it to dry. I guess impatience and taking shortcuts is a recipe for failure so this may not be such a good idea after all, I had that can of Bulldog setting there and while waiting on the epoxy to dry I just got to thinking so I thought I would ask.
Thanks
Old 10-13-2007, 05:23 PM
BarryK's Avatar
You may be beating yourself to death over nothing.
A lot if not most restorers will save the small parts like you are talking about and with piano wire dip the parts and hang.
Mix up a half a quart of epoxy in a paint mixing cup and dip the part, let hang and the excess will drip off in a minute and move on to the next.
Next day dip (if required) in your black paint or other solid color, same with bolts and nuts if needed.
This will not work on big pieces but leaves a nice smooth finish on smaller parts. (no it does not leave runs)
I try to accumulate all the small parts and will spend one whole day dipping in epoxy and next whole day dipping in paint to be efficient and not wasteful of material.
Old 10-13-2007, 07:23 PM
Holder350's Avatar
Auto Parts Professional
Bulldog seems to work great on plastic.
Does bulldog adhesion promoter need a primer? SplitFire Body - Exterior 9 08-09-2014 10:49 AM
Bulldog adhesion promoter. jcclark Body - Exterior 8 08-25-2005 06:29 PM
Barry, epoxy adhesion testing? baddbob Body - Exterior 21 03-20-2005 09:12 PM
adheasive promoter jefrohunter Body - Exterior 8 03-12-2004 06:24 PM
dupont waterborne adhesion promoter 327amc Body - Exterior 0 01-04-2004 05:18 PM
