Adhesive for door patches - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-13-2011, 05:13 PM
Mutt's37Buick's Avatar
Thanks for the feedback.
Just woudering:
1) Does the unit tell you what settings it is assuming when you use auto-set?
2) Now that you know how to weld, can you make better welds by selecting your own settings?
Thanks
  #17 (permalink)
Old 12-14-2011, 06:24 AM
deadbodyman's Avatar
Wiki Edits: 11
I saw a basic miller at a pawn shop for 250.00,it looked brand new ,I'll bet it never had a tank hooked up to it.Fine tuning the controls isnt very hard as long as you know what a good weld looks like.
  #18 (permalink)
Old 12-14-2011, 09:42 AM
with it autoset "on" you will not know what the wire speed is actually set on.
You will however know what voltage settings are. There is also a chart printed on the inside of the door that has various "set your own settings" for different types of metal.
The autoset is pretty dead nuts on as far as wire speed v.s. heat so I still find its faster and easier to just use this feature. I very seldom need to turn it off and manually set my settings. Stainless is the only example that comes to mind.
hope this helps.
  #19 (permalink)
Old 12-14-2011, 09:46 AM
Thanks for the help.
If I can find a used auto-set, it may be worth a little $ more to me.
It is unlikely I'll use another welder since I'm not a pro.
Thanks
Door Panel Adhesive clarification protour73 Interior 1 03-27-2011 08:54 PM
Body Support for patches slstusmc Body - Exterior 3 02-05-2006 09:01 AM
door glass adhesive galaxieguy3 Body - Exterior 2 09-21-2004 01:12 PM
Looking for Patches for Jacket... jchayden Hotrodders' Lounge 2 04-06-2004 07:12 PM
45 new cab patches ? biglee550 Suspension - Brakes - Steering 6 08-22-2003 07:36 PM
