Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Adj Brake Proportioning Valve?
Old 11-01-2005, 07:56 PM
yesgo yesgo is offline
abstruse dutch uncle
You should be able to get adapters to go from the bubble fares (I think they are also called ISO flares) to either standard INnverted Flare, or National Pipe Thread, to fit the adjustable valve. The adjustable valves like in the picture usually come with adapters to INF, because the valve body uses NPT.
There are adapters to go from just about anything to anything else when it comes to pipe and tubing.
