Adj Brake Proportioning Valve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2005, 04:07 PM
Where can i get one? it kinda needs to be metric and bubble flare would be nice as its going on my vw sandrail, thanks
Brendan
Old 11-01-2005, 06:54 PM
ragenrat638's Avatar
CRASH TEST DUMMY !!!!!!
the only thing i know is a brake flow adj valve..or pro-valve...summit sell's them... see picture...it's called a double flare....
sum-g3905
Old 11-01-2005, 07:00 PM
http://www.mpbrakes.com/
Master Power Brakes sells all kinds of brake parts and pieces.......and they are in your state......North Carolina. They cater to the street rod crowd......and are on the same road as a LOT of the Nascar teams......and should be able to help.
DEUCE.....
Old 11-01-2005, 07:56 PM
abstruse dutch uncle
You should be able to get adapters to go from the bubble fares (I think they are also called ISO flares) to either standard INnverted Flare, or National Pipe Thread, to fit the adjustable valve. The adjustable valves like in the picture usually come with adapters to INF, because the valve body uses NPT.
There are adapters to go from just about anything to anything else when it comes to pipe and tubing.
Old 11-02-2005, 05:08 PM
Dutchman's Avatar
Old Salt
Another place to obtain one:
www.speedwaymotors.com
Dutch
Old 11-02-2005, 06:01 PM
i like the one from summit, its $40 and does it install in like the front brake line? and it controls just the front pressure which acutlly controls all? do you know what i mean?
Thanks
Old 11-02-2005, 11:17 PM
It installs in the rear line ONLY.
Please read:
http://auto.howstuffworks.com/master-brake2.htm
Many people choose to use only the proportioning valve and not the metering valve for several reasons, including the fact you can buy it seperately and adjust it to suit your needs.... and 4 wheel discs normally dont need front metering. Front metering can be quite useful for disc/drum in the snow.
Old 11-07-2005, 02:10 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Thanks
It installs on the rear line to prevent premature lockup.
63 impala front disc brake conversion derwood3 Suspension - Brakes - Steering 6 12-27-2012 06:04 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Brake combination valve "Hook-up" HELP 39chevy Suspension - Brakes - Steering 1 09-14-2004 08:59 PM
Proportioning valve ztoy Suspension - Brakes - Steering 6 06-11-2003 02:55 PM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 02:36 PM
