Here's what mine looks like.
I'll double-check all the mechanical connections for fit.
Part of my prblem might also be the adjustment of a Ron Francis NS-600 neutral safety switch. It was easy enouh to install and adjust originally due to the plastic pin holding it in the neutral position. It woked fine for years.
As the result of a fluid and filter change, the switch was removed and has been problemmatic since then, never quite beng in adjustment (to trigger the backup lights and backup camera as well having to be "jiggled" to start the car).
Any advice on geting this adjusted as well?
