Adjust column shifter for 700-R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2012, 05:03 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Clutter
My rod uses a GM van O/D column-mounted shifter with the stock mechanical linkage shifting a 700-R4.
It's never really shifted smoothly or lined up with the PRNDL markings. Is there a HOWTO for adjusting it correctly?
Thanks.
Old 12-06-2012, 11:01 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Some slop in the linkage could be the problem. Be sure the column has P,R,N,OD,D,2,1
Park has a 'long' click and must be adjusted accordingly so your ride won't roll away without you...
Old 12-06-2012, 11:20 AM
hduff's Avatar
Here's what mine looks like.
I'll double-check all the mechanical connections for fit.
Part of my prblem might also be the adjustment of a Ron Francis NS-600 neutral safety switch. It was easy enouh to install and adjust originally due to the plastic pin holding it in the neutral position. It woked fine for years.
As the result of a fluid and filter change, the switch was removed and has been problemmatic since then, never quite beng in adjustment (to trigger the backup lights and backup camera as well having to be "jiggled" to start the car).
Any advice on geting this adjusted as well?
Old 12-06-2012, 11:24 AM
C-10's Avatar
Revolution Calling
Neutral safety switch. Didn't GM use one on the column? Not sure how a van column is setup...
Old 12-06-2012, 11:29 AM
hduff's Avatar
I don't really know; I'm not familar with that either. I added the NS-600 to run the backup lighst and camera and wired in the NSS as well. Do I not need the actal NSS function? That will make adjustment easier . . .
Old 12-06-2012, 11:57 AM
C-10's Avatar
Revolution Calling
If you want to fire up the engine 'in gear' then you can unhook the switch..
The flip side of that coin is, well, a big hole in your building if you mess up..
Might try and keep the NSS..
column to floor shifter camino_man General Rodding Tech 5 07-27-2007 08:24 AM
How to adjust column switch hi-low beams?? Hoonbash Interior 3 06-24-2007 06:49 PM
Column shifter on a mustang? geaux Hotrodders' Lounge 4 12-19-2005 09:06 AM
Column shifter options. Siggy_Freud Transmission - Rearend 3 03-04-2005 02:50 PM
Must play with shifter to start car- 700 trans BobbyG-39 Transmission - Rearend 2 08-13-2004 05:19 PM
