adjust R&P? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2007, 07:10 AM
adjust R&P?
Good morning. I have some slop in my Ford power rack. I see what looks lke a thin lock nut - big - and a slotted adjustment "bolt" inside the nut. Is this the way to adjust the rack and get rid of the slop?
Thanks, Robert
Old 04-27-2007, 10:04 AM
Yes, thats how to adjust the backlash between the rack and pinion gear.
I would mark the housing and nut before you start adjusting, only go about 1/4" of adjustment at a time and drive it to make sure it doesn't wander. You'll know it's too tight when the rack won't have any returnability after turns or wanders real bad.
As long as thats your only problem for loose steering anyway , it should help. What year, make, and model?
Old 04-27-2007, 10:28 AM
Thanks for the response. The car is a 1940 Chevy 2 door sedan street rod.
Can't adjust hyd valves 30 sportcoupe Engine 5 12-04-2004 05:07 PM
Adjust Edelbrock Carb bezmanianm Hotrodding Basics 9 06-15-2004 04:09 PM
valve adjustment 383 stroker solid lifter cam 73luvdrag Engine 4 05-15-2004 03:01 AM
Please HELP valve adjust? 1985fiero Engine 10 05-03-2004 06:50 PM
How do you adjust valves???? iroc_Camaro388 Engine 9 01-31-2004 11:54 AM
