adjustable coil-over shocks for jag rear - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-09-2009, 05:06 AM
earlf31's Avatar
Shorty
Andy,
You're right again. I count 5 the way you described the process.
Remember, I'm in the market for 1 set of adjustables. What do you recommend for spring rate, spring length and shock length (c/c). Brand name would also be appreciated. Remember, we were talking about a 12" length from c/c would give me a 3" gap from the rubber bumper to the suspension bar. If necessary, I would rather have more gap and a little more rake if you think it appropriate.
Earl
  #17 (permalink)
Old 05-10-2009, 05:32 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
According to the info you supplied, the rear springs on your car currently are supporting about 1425lbs at ride height.
With this info and converting it to 4 springs with the same rate, and utilizing your current coil-over shock dimensions, four 280lb/in springs pre-loaded to a point where your shock c/c measurement is 10 3/4" at ride height, you would achieve the same load capacity and you would have enough bump travel. If you wanted to go with an adjustable dampening coil-over, I would recommend a QA1 UR3955P with a 8CS 250 or 300 spring. If your car is riding very soft as you say, go with the 300's, otherwise I would recommend the 250's and just pre-load them to get to your ride height. Your choice...Keep in mind I have not been able to measure or even see your current set up so I am basing this recommendation on your specs. My gut feeling is to go with the 250lb/in springs, but you are the one who will be shelling out the cash, so the final decision is yours. You might ask about the return policy on the springs if you don't like the first choice. Usually if you don't scratch up the springs, they are returnable.
Final note...don't get springs that have been chromed! Get the powder coated ones.
Andy
  #18 (permalink)
Old 05-10-2009, 06:18 PM
earlf31's Avatar
Shorty
adjustable coil-over shocks jag rear
Andy,
I understand your response but, I am confused as it relates to my previous message wherein, I said I only wanted to go with 2 shocks, not 4. Are all of the specs you furnished for 2 shocks or 4 ? If 4 shocks, what are the numbers for 2 shocks ?
Earl
  #19 (permalink)
Old 05-10-2009, 07:35 PM
aosborn's Avatar
Wiki Edits: 7
As I stated in a prior post, I wouldn't recommend going with 2 coil-over units. But if you decide to, just double the spring rates I posted. The numbers I gave are for 4 shocks and springs.
Andy
  #20 (permalink)
Old 05-23-2009, 02:28 PM
earlf31's Avatar
Shorty
Andy Osborn,
You were right on the money. I purchased 4 QA1's from Speedway with the wrench. Adjustable shocks are 14" c/c with 10" 225 lb. springs. The shocks are set to full soft and I have a 2 1/2" gap between the frame rubber bumper and the suspension arm bell. It's perfect and the ride is outstanding. Thank you so much for all of your help, advice and calculations and to the other hotrodder's for the comments and suggestions.
Earl Fauerbach
  #21 (permalink)
Old 05-23-2009, 06:59 PM
aosborn's Avatar
Wiki Edits: 7
That's good to hear Earl, I was wondering how it all came out.
Glad to help,
Andy
  #22 (permalink)
Old 10-24-2012, 11:16 PM
New ask for Andy
Andy, i found this thread and seeing what a great job you did on the Jag suspension, i thought i would ask for some help on my own challenge. Building a kit (Ferrari Daytona) on a custom chassis with jag V12 running gear (i.e. same set-up as the othe rcar on this thread). The axle weights are 1450lbs front and 1680lbs rears. The front suspension is adapted with a Spax coil over shock replacing the standard Jaguar one. The problem here is that i have moved and changed the engine so the front is now hugely over sprung and need a lighter spring, but not sure what strength. The problem with the rears are that they are the original Jaguar coil overs that are also way over sprung. I am sure this is not enough information to answer the question, but be grateful for your assistance to work it out. thanks
  #23 (permalink)
Old 10-24-2012, 11:17 PM
correction
Andy, miss typed....front weight is 1450lbs, rear is 1380lbs, thanks
  #24 (permalink)
Old 10-25-2012, 12:56 AM
aosborn's Avatar
Wiki Edits: 7
Hey Peter,
Well, your situation is a bit more challenging than the last one. Why don't you do this...start a new thread giving some more details of your suspension system and I will do my best to come up with a spring rate that will get you in the ballpark. Keep in mind that what I prefer for a ride may not be the hot setup for you.
What we will need in addition to axle weight is the leverage ratio of the front and rear suspension (unless someone out there knows what it is for a Jag).
Unsprung weight of the front and rear suspension.
What the center to center (c/c) dimension of your coil-overs at ride height, fully compressed and fully extended.
How stiff or soft you would like your car to ride (highway cruiser with the wife, or corner carver with your buddy).
Given that information I can give you a fairly good guess as to what spring rate you should try first.
If you have any questions on how to get any of the above info, just let me know.
Andy
  #25 (permalink)
Old 10-25-2012, 07:13 AM
staleg's Avatar
Last journal entry: Hand brake
Have you checked Speedway Motors homepage?
Check these links:
http://static.speedwaymotors.com/ima...2553243A-R.gif
http://static.speedwaymotors.com/ima...lovermount.gif
  #26 (permalink)
Old 10-25-2012, 07:39 AM
Wiki Edits: 27
Jag irs
My son has an XJ6 Jag rear in his 22 dodge lakester, We built the chassis using the CCR T Bucket plans, added 4 in frame length in the rear, The CCR plans move the rear upper spring mounts inboard so they are also at a steeper angle. It still is too stiff in the rear, I have 4 Jag Irs, 2 XJ6 fronts, and 2 Jag F 40 fronts in the shop for our projects, so I'll be going thru the calculations. Another Good Resourse for spring calculations is Rod Authority, go the the tech button and down the the chassis button. I'll copy paste all the info you guys have posted and print a copy to keep in my suspension notebook.
  #27 (permalink)
Old 10-25-2012, 05:17 PM
started new thread
Suspension for Jaguar IRS for Kit
  #28 (permalink)
Old 11-20-2012, 11:52 PM
ferrari kit suspension
Andy, i posted the geometry and weights in the new thread. thanks for any help you can provide.
Coil spring rear suspension for 52 chevy coupe AustinPhoenix Suspension - Brakes - Steering 6 03-14-2009 09:27 AM
9 inch ford G body rear axle questions, advantages STD spring, coil over eatonde Transmission - Rearend 9 01-21-2009 11:11 AM
Spring rates for coil over shocks ken demer Suspension - Brakes - Steering 2 08-13-2006 05:27 PM
new : need advice on rear shocks 1 Hot Z Suspension - Brakes - Steering 2 02-21-2006 12:17 PM
mustang rear coil overs 347mustang Suspension - Brakes - Steering 12 11-13-2005 09:46 PM
