adjustable fan switch help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2006, 12:44 AM
Hello everyone,
I need some help with an buying a good adjustable thermostat fan switch. Their seems to be a lot available and a lot of price range. Most of all I want someting reliable. My current mr. gasket 190 switch seems pretty erratic, especially on its first turn on, last night it went up to 240 before it went on then it wont turn off till 160. I will probably be running a Lincoln MK8 fan, and from what I have read they pull alot of amps.
any help would be appreciated,
Thanks in advance
Jordon
Old 08-30-2006, 03:14 AM
Check for coolant flow and air locks before dismissing the part. Many factory fans won't cut in if the switch is only sensing air.
Old 08-30-2006, 07:12 AM
If you're going to be running a high-current fan, get a relay that will carry the current. Use your new temperature switch to control the relay similar to what is shown above.
Old 08-30-2006, 08:33 AM
302 Z28's Avatar
Personally I would not trust such a function to a Mr. Gasket switch. Get a good one from Vintage Aire.
Vince
Old 08-30-2006, 12:54 PM
Berliner Bel Air's Avatar
Beyond the Sea
I had this problem too. I think it was caused by switching the fan directly instead of using a relay, as suggested above. Ultimately I trashed that system and used an old Mercedes switch that I installed in the intake manifold. It looks stock (an old-looking brass sensor), and works perfectly. Fan cuts in when coolant reaches 100C (212F) and cuts out at 90C (about 195F). It now switches a relay.
Old 08-31-2006, 04:00 AM
If the switch you describe is the big ugly one used on the M110,M115,M123 etc they weren't all that reliable, I changed scores of them from 1978 to about 1990. The later, smaller red topped swich was much better.
Personally I'd look at using 2 switches - low fan speed at 90c and high at 110c. Check dirty little hyundais, I think they have a 90 degree switch. Also Benzs have a beaut 60 amp relay (the grey one) with HUUUUGE pins.
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
Trinary Switch from Vintage Air ElegantInventor Electrical 29 06-15-2011 06:44 PM
Rad fan switch?? Scrumgees Engine 7 07-04-2006 09:49 PM
Hot wire and fuse on aux. fan switch rapsag Electrical 13 06-23-2006 08:36 AM
electric fan (Adjustable temp switch) QUESTION 39chevy Electrical 0 06-16-2004 07:54 PM
