Adjustable timing pointer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2008, 12:28 PM
To check the adjustmnet of an adjustable timing pointer the way I understand it using a piston stop you mark the balancer where the piston hits the stop and then go back the other way to the stop and mark that on the balancer and then split the difference right? How do you guys find the middle of those two marks ie; tape measure?
Old 06-13-2008, 12:48 PM
King of my Man-cave.
You can use a tape measure or a degree wheel.
tom
Old 06-13-2008, 12:50 PM
Holder350's Avatar
Auto Parts Professional
easiest I'v found is to put your stop in the plug hole then adjust it as close as you can to stopping at exactly tdc.....then the marks will be 1/8-1/4 apart...then just eyeball from there
Old 06-13-2008, 12:59 PM
Works for me thanks. It shouldnt be off but its a mud racing engine and the timing pointer does a real good job of scraping the mud off of the balancer and just thought I should check it!
Old 06-13-2008, 01:04 PM
Holder350's Avatar
You usually have to worry more about the balancer spinning than the pointer bending.
Old 06-14-2008, 06:07 AM
Ran into something minor...when turning the engine backwards how do you keep the balancer bolt from backing out? I pulled all of the plugs but the stop I made must be catching some compression in #1 because the balancer bolt lossens up at a certain point before it gets back to the stop.Compression on this engine is pretty high.
Old 06-14-2008, 06:44 AM
SSedan64's Avatar
Go to Harbor Freight tools and get a flywheel turning tool, cheap $5-$10. Don't use the balancer bolt to turn the engine.
Old 06-14-2008, 07:46 AM
Holder350's Avatar
I always use one of these when the motor is together.
Thats Proform Pn#66782
I made mine....from a old crank pulley and socket.
checking timing pointer zephyrc Engine 4 06-03-2008 02:31 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
Timing advance issues... autonuerotic Engine 27 11-22-2006 06:51 PM
ignition timing (in relation to rpms) KNanthrup Engine 8 05-21-2006 04:16 PM
Timing problem - Help MTMike Engine 1 11-13-2002 01:07 PM
