Adjusting the air/fuel on a holley. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2009, 04:02 PM
If your running a single carb and screw the air/fuel mixture screw all the way in the car will start to die, right? Well if your running dual carb's will the engine still die? I'm having a hard time getting these dual carbs tuned correctly.
Thanks!
Old 03-03-2009, 04:48 PM
tubbedz's Avatar
I once had a tunnel ram setup on a SBC with two Holley 600cfm, 4-corner idle carbs. If I turned one idle mixture screw in, the car would stutter and want to die. It was a little difficult as I had a total of 8 idle mixture screws.
« 283 | Hot Rod Title »
Holley - adjusting idle mixture Daz_uk Engine 4 11-01-2008 05:09 PM
Help Needed Adjusting Holley DP Mustangsaly Engine 16 07-11-2008 12:17 PM
adjusting floats on holley carb inquiring_mind2 Engine 1 04-24-2008 09:29 PM
can you help with adjusting dual holley set up? jjsticks Engine 5 05-09-2007 05:04 PM
Adjusting Holley idle pszikszai Engine 5 08-12-2006 12:25 PM
