Adjusting Brake Pedal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2012, 09:28 PM
LBL's Avatar
LBL LBL is offline
Running Down the Road
Last journal entry: Interior
I recently swapped my front drums on my 1959 Ford Ranchwagon for discs with a booster and proportioning valve. I think that the pedal is going too far down and am wondering how to adjust the whole setup. I have vacuum bled the brakes and am pretty sure that the brakes are properly bled but I am wondering about the linkage from the pedal to the booster and the the little threaded adjustment on the output side of the booster that actuates the master cylinder. Can I just keep lengthening the rod from the pedal to the booster or is there a point where I've gone too far. Same for the little adjuster on the output of the booster, can I screw it out too far ? I should mention that the brakes do stop the car, I just think that they should be actuated sooner ..Thanks
Old 09-21-2012, 07:50 AM
RWENUTS's Avatar
Did you change the pedal ratio under the dash.
Here's an excellent link.
Classic Chevy, Chevrolet, GMC, Ford technical articles
Old 09-21-2012, 08:12 AM
LBL's Avatar
LBL LBL is offline
Thanks
That is a very informative link, I'll check that all out this weekend ..
Old 09-21-2012, 07:59 PM
Cape Cod Bob's Avatar
Did you adjust the rear drums up properly. Should stop after 1 rev when spun by hand.
Relationship between Gas Pedal and Brake Pedal 35WINDOW General Rodding Tech 12 01-11-2012 01:35 PM
Self adjusting brake adjuster access rustman Suspension - Brakes - Steering 11 05-27-2011 03:27 PM
brake pedal sxcorpio Suspension - Brakes - Steering 1 04-24-2007 08:41 PM
51 chevy drum brake adjusting??? swain66 Suspension - Brakes - Steering 1 10-09-2004 08:31 PM
brake pedal astrops Suspension - Brakes - Steering 2 06-02-2004 07:32 PM
