adjusting cam duration by using smaller/larger timing gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2006, 07:56 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Would it be possible to adjust the duration of your camshaft by altering the diameter of the gears on your timing chain. If this is possible then why doesn't the cam manufacturers or companies who make timing chains offer different size gears. It would be like adding a bigger cam by just changing gear sizes.
Old 03-16-2006, 08:00 PM
NorthStar's Avatar
Thats impossible.
Old 03-16-2006, 08:12 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The cam timing gears, chains, belts, whatevers are a 2:1 ratio. For every time the crank turns twice, the cam turns once. That is set in stone. It absolutely has to work that way because its a four-stroke engine. Altering the size of the gears would cause the cam to be out of timing the instant it began to move.
Old 03-16-2006, 08:15 PM
dh79's Avatar
Changing duration through the gears is not the way things work. The gears are on a 2:1 ratio so that the valve timing stays true. If you changed the ratio on one gear the valve timing would then change and continue to change for each rotation. Run away valve timing...
81 Grand Prix, 355, 700r4, 8.5" 4.10
64 Oldsmobile Jetstar, all original
Old 03-16-2006, 08:16 PM
dh79's Avatar
haha, beat me by a couple seconds
dh
Old 03-17-2006, 01:36 AM
Yeah, good idea. Run 4:1 gears so your 12:1 comp drops to 6:1 with the exhaust valve opening midway through the compression stroke, you should use at least one 14/71 per cylinder and 360 psi boost.
I'm gunna tell the DEA about you. Happy smokin'.
Cam timing KNanthrup Engine 4 08-17-2005 11:15 PM
cam affecting timing ? hotrodder442 Engine 1 06-24-2004 09:53 PM
cam timing off??? Pony Engine 2 05-08-2004 10:21 PM
oil leak when adjusting timing?? Trav Engine 14 11-15-2003 10:55 AM
Cam, gears, convertor and weight??? HemmiGremmie Engine 5 08-16-2002 07:31 AM
