Adjusting Coilovers? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2008, 06:29 PM
S10xGN's Avatar
Gotta love a turbo!
Hi All,
I've got Aldan coilovers at all 4 corners. How do you adjust the spring height? I've got a spanner wrench, but the spring seat is too difficult to turn without unloading the spring and my (old style) spring compressor won't work on these with the shock body so close to the spring...
Russ
Old 02-05-2008, 06:57 PM
powerrodsmike's Avatar
Wiki Edits: 161
You are supposed to have a bit of anti seize on the threads and spring seat. That makes things much easier.
You can also jack up the car, adjust the spring collar up a few turns, then set the car back down and jounce the suspension a few times to get it to settle down to it's ride height.
Later, mikey
BE different....ACT normal.
Old 02-06-2008, 08:12 PM
S10xGN's Avatar
Gotta love a turbo!
Mike,
I thought about that, but I'm not sure... if I unscrew the seat off the body (to lube the threads), will the spring "pop" off? Will I be able to get it rethreaded OK? I mean, it seems like there is still a bit tension with the seat almost unscrewed.
Russ
Old 02-06-2008, 10:21 PM
Wiki Edits: 161
Most of the ones I've dealt with will get loose before you run out of threads..you wiil be able to tell if the spring is loose enough to turn easily by hand, you are almost there. You can also lube the threads some below the spring collar, run it towards loose a ways, then with an acid brush, smear some anti seize or white grease on the threads above the spring collar, reaching in through the spring..
Then crank the collar up. This will spread the lube where it needs to be, and you dont have to take the shock apart to lube and adjust it. .
I use a big syringe with a #14 needle that I got from the feed store for stuff like that.
later, mikey
Old 02-07-2008, 06:31 PM
S10xGN's Avatar
Gotta love a turbo!
That was it, Mike. I took a closer look at the seat "nut" and it's about 1" deep. The spring got loose before it unthreaded all the way. The shock bodies came prelubed and I added a bit more. Still pretty hard to turn though...
Russ
Old 02-09-2008, 12:15 AM
Duane lxiv's Avatar
Last journal entry: headliner bow ends
Here's the solution
You get thrust bearings and washers from QA1 available from J**'s and others.
The bearing goes between two washers then under the spring, very little friction.
Makes adjusting a lot easier
cost under $30.00
best way of adjusting valves SBC ??? Augusto Engine 33 03-22-2011 05:04 AM
Is there a foolproof way of adjusting the THROTTLE VALVE? scot Transmission - Rearend 1 11-09-2005 04:53 PM
Coilovers, how do you adjust them? jgrant Suspension - Brakes - Steering 8 10-30-2005 07:44 PM
Chrome Coilovers 33chevy-guy Suspension - Brakes - Steering 3 07-25-2004 08:30 PM
Coilovers and mounting GLN305 Suspension - Brakes - Steering 8 09-29-2003 09:02 PM
