adjusting the hood and doors on my 1949 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2011, 04:02 PM
can some please help me adjust the hood and doors on my 1949 chevy pickup. i cannot get the doors to close all the way nor the hood. the hood has about a 2 inch gap between it and the fenders with the hood all the way down. by the way it does have a 1969 nova front end under it. that's probally is the problem. but these doors came off of this truck but they were not fitting properly before. please help if you can.
Old 12-04-2011, 04:39 PM
I cant remember about the doors, I will have to go out to the shop and check those... But the hood adjustments are on the firewall.. two bolts that hold the spring. Loosen and slide the bracket up or down on both sides. I think the front of the hood is adjusted by the locking mechanism. Hope that helps a little.
Old 12-04-2011, 04:57 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
doors adjust to the cab. hood adjust to the cab. fenders adjust to the hood. you may have to shim the core support. loosen the door hinges so you can bump the door around. it's not that hard once you get the hang of it.
Old 12-04-2011, 05:53 PM
Check to see if the door is closing on the first or the second latch. That is one of the biggest mistakes made, the guy thinks he needs to move the striker in to tighten the door more but the latch is only grabbing on the first latch and the door doesn't go in far enough. Gently push the door shut and see how many times it clicks. If if only clicks once, the first latch is all that's catching and you need to pull the striker out a little so the second latch can catch.
When I say "first and second latch" I am referring to the the two "steps" of the the latch, not two different latches.
Old 12-04-2011, 05:54 PM
doors and hood adjustment
thanks a lot
Old 12-04-2011, 05:55 PM
Shine is probably right that the mount of the rad support is simply too low needing it to be shimmed up. However, check the rad support rods that go from the firewall to fenders out at the rad support, they are VERY important on these trucks to pull in the upper fender making them tighter to the hood.
Old 12-04-2011, 07:43 PM
shine's Avatar
SPI Thug
i adjust door without the latch . when the door is right then install the latch and adjust it to the door.
Old 12-04-2011, 08:16 PM
texastomeh's Avatar
GREAT tip!!!!
Tom
Old 12-04-2011, 11:46 PM
You are absolutely right if you are needing to go up or down or something like that. But once that is done and you are talking about the door not latching all the way, look at it as I suggested.
carpet in a 1949 chevy pickup tbrown8338 Interior 2 10-29-2011 07:04 AM
adjusting my doors on my 34 Chevy 3 window coupe robbie34chevy Body - Exterior 6 04-17-2006 12:15 PM
1949 chevy pickup sumdaymyownshop General Rodding Tech 3 02-14-2005 08:20 AM
Where is the serial # on the 1949 chevy pickup 49dream Transmission - Rearend 2 08-03-2004 10:13 AM
'54 Chevy Pickup - Adjusting the Doors horvath Body - Exterior 26 05-15-2003 04:47 PM
