Adjusting idle mixture screws - vacuum source - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2011, 08:15 AM
Snoopy'sVette's Avatar
When adjusting the idle mixture screws, I am supposed to hook a vacuum gague and adjust the screws to get the most vacuum, where do I connect the gague? I heard there are two types of vacuum, ported and manifold?
In the third picture, the port on the bottom rear of the carb, is that a good source?
Old 02-07-2011, 09:45 AM
Snoopy, yup that one should work fine, any port below your throttle plates on a carb is a source for manifold vacuum.
Holley - adjusting idle mixture Daz_uk Engine 4 11-01-2008 05:09 PM
Idle mixture screws not working V305 Engine 7 10-05-2008 07:15 AM
Idle fuel mixture screws adjust kleen56 Engine 6 10-02-2008 10:07 AM
idle mixture screws 72Orange Engine 14 09-28-2006 01:30 AM
Idle mixture screws only turned out 3/4. Runs good. BrackneyC Engine 1 04-28-2003 03:58 AM
