Adjusting individual shift points in AOD possible?
91 AOD new rebuild, Transgo HP kit, shoved into a 65 Mustang behind 360ish horsepower 302, 2500 stall, 3.73 gears, Lokar linkage, Holley 570 with linkage corrector. It shifts extra early in 1-2 along with 3-4. I plan to pull the valve body back out and reinstall the stock 3-4 valve and springs based on conversation with Transgo along with findings on the net. Transgo wasn't quite as helpful on the 1-2 issues, though. Line pressures are good and acceptable to Transgo. Here's a video of what I'm talking about http://www.youtube.com/watch?v=EtiuEmalSVM . Part throttle is lousy, 1/2 better except for 3-4, full throttle is fine, 2-3 shifting is good at all speeds and I'd like to copy that in the other shifts.
I'd installed the governor from transgo which has nice WFO shift points, but I decided to go with another valve body as I believe this one is fubar. I went through it, made some tweaks, but it still tangles up the shifts and the TV is already well above spec just to "work". I'll find out in a week how a Silverfox vb works. He gets high praise.
I eventually went with a full manual, reverse pattern valve body because I wanted total control in all circumstances. You might think about that. No regrets at all with the TCI unit. It does not have engine braking and I was worried about that before install; but I believe now that it's a plus. It makes the car more streetable because down shifts won't brake you if you are not RPM matched - and there is not the jolt I expected when you spin up your engine to meet the drive train, so to speak, under those circumstances. It's completely useable on the street, and for the strip it's great with the ratchet shifter. If your car is more racer than anything else, I say go manual valve body. Yep, I can drive my car to work, taking off in 2nd gear (4:10 rear). On race day, I open my exhaust dumps, hook up the bottle, toss in the helmet and I'm in a different animal, a really different animal. You can tell I love the outcome of this Mazda RX-7 V8 conversion project. Good luck with your tranny.
AOD Facts
Visit this site and do a lot of reading this is a hard core AOD site: www.clickclickracing.com
I don't know if Baumann is still around, but they were heavies with the AOD.
Then there's Lentech. Give them a call, they know their way around a Ford overdrive automatic. |
I thought the manuals had braking?? Is yours something different or was I always believing the wrong way? How about 1st braking? |
My trans is a GM 200-4R and I went with the TCI full manual valve body, none of the gears will produce engine braking on this particular body, although I wouldn't slam it into 1st at speed. It wouldn't brake, but it might break! Something internal spins-up on down-shift, and the faster you are going on the down-shift, the faster that something spins (drum?). Anyway, I can tell it would not be healthy to do that manuever - but no it wouldn't slow the car.
| the Shift Points | Midnight Run | Transmission - Rearend | 1 | 07-31-2009 10:39 PM |
| Adjusting shift points on 700R4 tranny | andre22 | Transmission - Rearend | 3 | 01-22-2008 05:14 PM |
| Adjusting shift points for C6 | '67Pony | Transmission - Rearend | 1 | 01-05-2004 03:31 PM |
| Shift Points??? What to do | thiems | Transmission - Rearend | 11 | 04-09-2003 05:45 PM |
| C6 Shift Points | leefc | Transmission - Rearend | 9 | 11-01-2002 08:35 PM |
