adjusting proportioning valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2002, 05:49 PM
New Member
Post adjusting proportioning valve
Just installed disc brakes on the front of my 47 Desoto. I am using a proportioning valve and am wondering how to go about setting it. I am running stock drum brakes in the rear with residual valves. Thanks for any help. Stoke
Old 05-06-2002, 06:20 PM
Wink
Information I've seen on these models modified with disk brakes and stock rear drums is that a proportioning valve is rarely needed. Here's some poop on 'em anyway>
<a href="http://www.howstuffworks.com/master-brake3.htm" target="_blank">http://www.howstuffworks.com/master-brake3.htm</a>
Old 05-06-2002, 08:14 PM
4 Jaw Chuck's Avatar
Post
For street use you should empty as much out of the car as you can, spare tire, tools etc, near empty fuel tank too. Start on some wet level ground in a place where you can do this in peace without the law getting in the way and ruining your day, a highway at night on a deserted road is alright but bring a friend who can watch the rear tires from outside. Turn the valve in all the way to restrict the fluid to the back brakes. Do some hard stops to get the brakes hot and make sure your rear brakes are adjusted properly, slowly make a few quarter turns out on the valve and do a hard stop in between each adjustment to see if the rears are starting to grab. This can take awhile but usually you'll have a feel for how much a quarter turn will get you. The idea here is to get the rears to start doing their share of the braking without ever locking. Once you get them to lock back off on the valve a quarter turn, then test them again and again until you are sure they won't lock under heavy braking on the wet road. This is the best way to set it on a street car. After your done mark the knob or remove it so you don't accidently change this setting. Some valves are extremly sensitive to even a 1/32 of a turn or half a click so once your close make fine adjustments.
Outlawed tunes from outlawed pipes
