-   -   Adjusting Proportioning Valve (http://www.hotrodders.com/forum/adjusting-proportioning-valve-228863.html)
rusty duck 01-26-2013 11:35 PM
After the prop valve is installed what is the best way to adjust it?
454 Rattler 01-27-2013 09:47 AM
You might try doing a search on this site. Lots of info on it.
454 RATTLER
MARTINSR 01-27-2013 10:07 AM
I think this is a good discussion on the subject. http://www.hotrodders.com/forum/prop...ent-40527.html
OneMoreTime 01-27-2013 11:13 AM
As a practical matter start out on a gravel parking lot where you can easily see the marks made when you make a hard stop. The it takes several runs to get the brake bias somewhere close so you have even braking on both ends..then we proceed to the track where we can make faster runs and do some more testing to get a fine tune on the brake bias..Hope this helps a bit..
Sam
