Adjusting Proportioning Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2013, 10:35 PM
After the prop valve is installed what is the best way to adjust it?
Old 01-27-2013, 08:47 AM
454 Rattler's Avatar
NEVER SATISFIED !!
You might try doing a search on this site. Lots of info on it.
454 RATTLER
Old 01-27-2013, 09:07 AM
I think this is a good discussion on the subject. Proportioning Valve Adjustment
Old 01-27-2013, 10:13 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
As a practical matter start out on a gravel parking lot where you can easily see the marks made when you make a hard stop. The it takes several runs to get the brake bias somewhere close so you have even braking on both ends..then we proceed to the track where we can make faster runs and do some more testing to get a fine tune on the brake bias..Hope this helps a bit..
Sam
Proportioning Valve rusty duck Suspension - Brakes - Steering 4 07-20-2011 08:24 PM
adjusting proportioning valve yragat Suspension - Brakes - Steering 13 06-17-2008 11:48 AM
proportioning valve fred56 Suspension - Brakes - Steering 11 12-21-2005 02:46 PM
Adjusting S-10 Proportioning Valve TurboS10 Suspension - Brakes - Steering 2 09-09-2003 01:44 PM
adjusting proportioning valve stoke46 Suspension - Brakes - Steering 2 05-06-2002 08:14 PM
