Adjusting Roller Rockers On 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2012, 11:34 PM
How Many Turns Do You Tighten Them -some Say 1/4 Turn ,others Say 1 Full Turn- Hydraulic - Flat Tappet Cam
Old 03-18-2012, 07:20 AM
the "book" says 1 turn.
"performance books" say 1/4 turn.
Everyone tends to pick their adjustment somewhere in between the two.
Try both and try somewhere in the middle to see which one you like the best.
I prefer to split the difference and run around 1/2 turn.
Old 03-18-2012, 10:10 AM
Adjusting roller rockers on 454
Yeah, I've been setting them at 1/4 turn plus a little to set the lock.seems to work OK ,use to do them running but this is a lot cleaner. Maybe I'll try a half turn this time. Thanks...................................Gus
any difference when adjusting roller rockers over stock rockers, using self aligning? redfish211 Engine 1 10-12-2011 03:12 PM
SBC adjusting roller rockers. pittbull7934 Engine 27 10-05-2009 06:30 PM
adjusting rockers GIXXER07 Engine 2 08-07-2007 05:27 AM
adjusting rockers Slant3 Engine 10 08-28-2004 02:06 PM
Adjusting valves with Roller tip rockers...... joakes Engine 6 10-19-2002 05:54 PM
