-   -   Adjusting the secondary butterflies on a Holley? (http://www.hotrodders.com/forum/adjusting-secondary-butterflies-holley-223370.html)
Madmax305 08-26-2012 01:05 PM
Would something like this work on a Holley Street Avenger 670 with vacuum secondaries, or should I just put in a new allen screw from the top of the throttle plate. Any suggestions on what you guys have done to make adjusting the secondary butterflies easier. :confused:
ProformParts.com - ADJUSTABLE SECONDARY CAM BRACKET
RWENUTS 08-26-2012 04:57 PM
I took a small flat blade screwdriver, heated it a bit with a propane torch and bent a 90 in the end.
Then I could reach under and adjust it without removing the carb.
What type of a screw head does yours have?
Madmax305 08-26-2012 06:07 PM
It has the stock slot head screw...I was thinking about removing the screw and replacing it with an allen type and then re-install it from the top, where it would be a lot easier to adjust.
RWENUTS 08-26-2012 06:29 PM
That works to.
GREENBIRD56 08-27-2012 08:13 AM
secondary screw location
Usually - on most manifolds there is nothing in the way below the carb. But...it is often very painful to get on the screw with a driver (regardless of the type of head you install) from the bottom due to heat and other obstructions.
A fellow showed me the "hillbilly" way and I've used it ever since. Replace the screw with a longer fully threaded one - that sticks out far eough to tweak it with needle nose pliers. Doesn't have to be way too long - just enough.
RWENUTS 08-27-2012 11:16 AM
Or replace the screw with a machine screw that a 1/4 inch wrench will fit.
