Adjusting the secondary butterflies on a Holley? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2012, 02:05 PM
Madmax305's Avatar
Would something like this work on a Holley Street Avenger 670 with vacuum secondaries, or should I just put in a new allen screw from the top of the throttle plate. Any suggestions on what you guys have done to make adjusting the secondary butterflies easier.
ProformParts.com - ADJUSTABLE SECONDARY CAM BRACKET
Old 08-26-2012, 05:57 PM
RWENUTS's Avatar
I took a small flat blade screwdriver, heated it a bit with a propane torch and bent a 90 in the end.
Then I could reach under and adjust it without removing the carb.
What type of a screw head does yours have?
Old 08-26-2012, 07:07 PM
Madmax305's Avatar
It has the stock slot head screw...I was thinking about removing the screw and replacing it with an allen type and then re-install it from the top, where it would be a lot easier to adjust.
Old 08-26-2012, 07:29 PM
RWENUTS's Avatar
That works to.
Old 08-27-2012, 09:13 AM
secondary screw location
Usually - on most manifolds there is nothing in the way below the carb. But...it is often very painful to get on the screw with a driver (regardless of the type of head you install) from the bottom due to heat and other obstructions.
A fellow showed me the "hillbilly" way and I've used it ever since. Replace the screw with a longer fully threaded one - that sticks out far eough to tweak it with needle nose pliers. Doesn't have to be way too long - just enough.
Old 08-27-2012, 12:16 PM
RWENUTS's Avatar
Or replace the screw with a machine screw that a 1/4 inch wrench will fit.
Adjusting the butterflies on a Holley? Madmax305 Engine 2 08-12-2012 02:17 PM
holley secondary bog chevythmpr Engine 14 11-04-2009 09:10 PM
holley secondary problem yragat Engine 20 07-25-2007 06:42 PM
are my secondary butterflies opening? Augusto Engine 3 10-29-2006 09:09 PM
adjusting the secondary air valve? (Q-Jet) red406 Engine 9 09-27-2006 06:35 PM
