Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Adjusting trans linkage
Old 12-10-2009, 05:03 PM
Cape Cod Bob's Avatar
Cape Cod Bob Cape Cod Bob is offline
There should be an adjustment on the linkage closest to the tranny.Loosen it and put the lever in P and be shure the tranny is in P . Retighten and run the lever thru the gears to see if you get them allwith the motor off. You may need a more adjustable linkage available from Kugle.
