Adjusting vacuum advance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2010, 10:44 AM
I put a summit distributor kit on my 350 in my '78 camaro. The motor is a 350 headers Holley 750 duel line, Edelbrock performer intake. The advance is adjustable, but I set the timing and say 15 degrees base, then I hook up the vacuum to the advance it jumps to around 40. I tried turning the screw inside the can either way and I don't seem to get a different result.
Old 05-16-2010, 02:16 PM
DoubleVision's Avatar
Slow the timing down to 12 degrees before top dead center with vacuum advance disconnected and plugged. Rotate the inner screw of the vac advance counter clock wise to reduce the amount of vac advance, as you move it you should feel a click or a notch, Back it down 1 whole turn, reconnect the vac advance and check the timing. Your shooting for 20-24 degrees at idle.
Old 05-17-2010, 10:26 AM
I also noticed to get it to idle good at around 650-700 rpm in gear, it idles at a little over 1000rpm in park. I was told that was way to high in park. Also the carb is a 750 Holley duel line with the vacuum secoundary disconnected and a nut and bolt on the linkage for mechanical secondaries with no choke. Is this too much carb for this motor I was told yes, and no. With no choke will I have to let it warm up before I drive it? It seems to run better, more power, after I let it run for a little bit and give it some gas.
Also I run the vacuum line to the side of the carb on the idle mixture plate now, it seems to have just as much vacuum as the port under the fuel bowl that I used to run it to. Is this right?
Old 05-17-2010, 10:43 AM
If that`s the only mods done to your 350, and everything else is stock then yes, you have too much carb. The stock cam is pathetic, the heads are like corks, and the compression is dirt low. Getting a 600 Holley or better yet, A Quadrajet will fill the bill nicely. It should idle around 800 RPM. When when put in drive it should drop to around 700. You can connect the vac advance line anywhere it`s pulling vacuum full time. If it`s pulling vacuum at idle is the clue it operates full time. I would never place a bolt and nut in the secondary slide and why is because if there isn`t a pump shot for the secondary side when it`s forced in which will cause a bog. Also if the secondary`s aren`t working then it`ll go dead lean and pop back through the carb when the secondary butterflies are forced open without any fuel.
Old 05-17-2010, 10:51 AM
The motor is early 70s 350, Edelbrock intake, Hooker Headers, mild cam around .488 lift, the 750 Holley, Flowmasters and an electric fuel pump. I think the bolt was set right, when the secoundaries open the rpms grealty increase and it sounds very mean. I was told to just unhook the advance with the cam I have, I was told the fuel millage would suffer, but with the intial timing set right there would not be any detonation or anything bad. The distributor has a new rotor, cap, harness, capacitor, module, new weights, and medium springs.
Old 05-17-2010, 11:26 AM
I was hoping I didnt need a stall, but believed I probably would. But what about the advance question, need it or not?
Old 05-17-2010, 02:50 PM
I was told by the builder of it that it was a .488 lift, thats all he told me about the cam. Is the port on the side of the Holley fuel metering block supposed to have vacuum at idle?
carb tuning help needed biscuitville Engine 23 08-04-2008 07:49 PM
Timing/carb idle mixture adjustment DENCOUCH Engine 7 07-21-2008 11:50 AM
intake leak? cope Engine 4 05-08-2008 07:59 PM
Vacuum advance adjusting? k-man Electrical 5 11-01-2007 09:45 PM
68 charger lights T-bucket23 Electrical 5 08-14-2006 05:07 PM
